Outside air kit install question
steevo
89
central ct
I have an enviro Windsor pellet stove, and I would really like to install and OAK if possible. My issue is that the stove it installed on our fireplace hearth and backed up right to the fireplace opening. I have it vented through my chimney liner.
Looking at the kits I see online, most OAK go through the wall. It appears my only option is to go through the brick fireplace to outside.
Would it be possible to drop a flexible metal hose down the ash dump of the fireplace ( door removed ) and drop it down into my basement so the other end sits open in my cool basement?
I would rather not drill through the brick if possible,
thanks
steve
If you have a liner running to the top of chimney,you could use the chimney as fresh air,may have to have the block off plate custom made.Others will chime in.
Dropping it down the clean out is OK
Just remember the air that is used in
combustion leaves the building and
has to be replaced with outside air so
find some where you can get the pick
up point Outside the house .
