I have a Harman P61a, and I have a question. I have a spare chimney flue that is not in use. I am thinkihg about hooking up to it for outside air. Would the draft of the chimney be too much for this to work? Thanks.
Run a pipe to the top of it.I have a Harman P61a, and I have a question. I have a spare chimney flue that is not in use. I am thinkihg about hooking up to it for outside air. Would the draft of the chimney be too much for this to work? Thanks.
I don't think many would say you will have a 'problem', per se, the problem is,I have run my stove for two years without outside air. No problem.
)Hehehe... it always, for whatever reason, comes to a discussion about OAK good vs. OAK bad.My question was about using a chimney flue
only way i think you'll be able to tell if is struggling or not.. is with something to measure air flow.Yes, was planning on sealing well. figured it was worth a try if it doesn`t work well I will go back to no OAK.
Thanks
if you ever stick your hand over the exhaust outside, that rush of air
that you feel, is being replaced with cold air from outdoors.
If it's 0° outside, that is what is trying to get
inside, to keep you fire going.. and it does.
So without OAK, you are using air that you have heated,
for combustion. If you have a super efficient house,
you may not get enough air to satisfy the demand..
But that is everyone's own choice/opinion...
I use one on both my stoves.
Dan
(and I do not claim to be smart..)
