agartner said:During or after? If the things glowing, its a bad thing. If it warps, its a bad thing. If there are weld seams, shine a flashlight from the inside to see if the seams cracked thru. When the stoves cold. Stovetop thermo is your best friend. If the needle is buried, its a bad thing. Most stoves though can take some pretty high temps though. Mine has seen 750 on a few occasions when i wasnt paying attention, no harm done, although it was a bit unnerving the first time.
smmm said:What are signs to look when you are over fire a stove?
wmarazita said:I had the same question on my new Englander 30.
The manual gives this warning: "DO NOT OVERFIRE. If the heater or chimney connector glows, you are overfiring". That seems obvious, but I couldn't find any reference to an "overfire" temperature. As I get to know this stove, what recommendation would you all have for a "cruising temp" and when should I be concerned about an "overfire" temp? My thermometer is on the top of the stove just South of the rise in the top.
Thanks!
Well, after 40 years of burning wood to keep my butt warm, that sounds like some pretty sound, reasonable, and practical advise! My Dad had a Buck Stove like mine and he ran the damn thing wide open all the time and never ruined it. But then my Dad could get away with anything! I have always errored on the side of caution. My Buck looks like the day I installed it in 1982. It has been real hot more than once, but a well made stove will take a lot. Just use common sense. If you think it is to hot, it probably is. Just shut it down and it will most likely be fine. :coolsmirk:pen said:wmarazita said:I had the same question on my new Englander 30.
Thanks!
A recommendation like that is what it is. If it's glowing, it's too hot.
W/ a thermometer on that stove where you mentioned it is the hottest spot. For my own stove, I run between 550-650 normally (this time of year). When it's cold I'll bump that up to 750 for an average top end. It's damn cold, and the house matches, I'll let her see 850. Wife has had it 900+. It may go over 800 3 or 4 x per winter.
That's what I do, not saying it is right. Stove is on it's 4th year and no signs of warping, discoloration, or splitting in 1/2. Unit has never had a glow anywhere (couldn't say that for the old fisher) Original baffle boards are in place, original burn tubes look great when dusted off. Don't know if mine will last 10 years or 30 years the way I run it but for the price of this American made piece of steel and what I paid for it, I could replace it every few years and still be way ahead. I run it that way because that's what I need to keep this place comfortable.
To the Original Poster, while I haven't run your stove, that is another tough unit. I'd say looking at 700 as the redline for good high end temps and good life expectancy is a reasonable figure. It certainly takes more than that to start glowing.
pen
smmm said:I love this forum. You guys are cool. No one has yet made fun of my novice questions.
Truely sincere. Thanks.
Hell, I been burnin for 40 years and I am still figuring it out......and loving every minute of itsmmm said:I love this forum. You guys are cool. No one has yet made fun of my novice questions.
agartner said:smmm said:I love this forum. You guys are cool. No one has yet made fun of my novice questions.
I've never seen anyone here ever be rude or make fun of someone's question, with the possible exception of a couple of our old timers and their perpetual debate on the advantages and disadvantages of using horizontal vs vertical wood splitters.
In all seriousness though, we're here to help and there is a treasure trove of knowledge in the historical posts. I've learned more about burning my stove properly by just sitting down and either searching for various topics or just outright reading the discussion threads in these forums. Some of the threads are just entertaining in their own right, even if you don't learn anything!
Amazing place. Stay warm!
