I've overheated every boiler and furnace that I've ever owned, often on multiple occasions. After owning my EKO 60 for more than a year, I finally got around to doing it last weekend. In the process of swapping in the new controller model, I neglected to re-connect the circulator, fired up the boiler, went for a bike ride, and returned an hour and a half later to an overheated boiler.
The last thing you want to do in a situation like this is the first thing your instincts tell you to do, which is to get the pump going and move some cooler water into the boiler vessel. Wrong.
If you do that, and wind up pumping 250-degree (or whatever) water into the rest of your system, you run the very real risk of blowing out any pex you might have plumbed into your piping, damaging pumps and expansion tank bladders, etc. I know people who have blown out underground pex runs in the dead of winter this way. No fun at all.
Instead, do what you can to cool the boiler down to below 200 degrees before firing up the circulator again. Since my boiler is in the barn, I was able to pull a bunch of half-burned chunks out of the firebox and toss them out into the snow, along with a couple shovel-fulls of hot coals. Don't try this if there's anything flammable between the boiler and the water/snow source. I have a manual overheat loop piped into a couple of cast iron radiators in the barn attic, which I opened up to hasten the dispersal of the remaining heat. I also opened the boiler room doors and let cold air circulate around the boiler. Then I went inside and had dinner and a stiff drink (not necessarily in that order).
It took about two hours for everything to cool down to the point where I felt confident re-engaging the pump.
Overheating is not, by itself, going to hurt your boiler. Assuming your pressure relief valve is working correctly, the worst that will happen is that enough pressure will built up in the boiler to lift the valve and vent a big cloud of steam and hot water into your boiler room. Hopefully your makeup water line is open and any lost water will be immediately replaced.
The moral of the story, of course, is to have an automatic, gravity-feed overheat loop plumbed into your system. I have an Automag zone valve for the automatic part, but it's sitting on a shelf in my basement instead of being plumbed into my piping. Silly procrastinator that I am. Barring that, some sort of overheat alarm or power-out alarm is a very good idea. A nightmare scenario for my system (and probably most others) would be a power outage while you're fast asleep, allowing the boiler to overheat, and then the restoration of power a couple hours later, which would result in the unfortunate pumping of excessively hot water into the rest of your system.
Something to think about.
I now fully respect pressure!
