P68 exhaust fan replacement
SininStyle
Burning Hunk
Mar 8, 2013
161
I replaced my exhaust fan sure to the old one starting to lose a bearing . Straight forward, rewired, runs fine.
The issue is now my auger won't turn on. Test shows motor light, both fans blow fine. It was running before the install. Don't see any dangling wires. Test runs and runs, distribution blower shuts off, motor light shuts off, exhaust keeps running and rest never ends.
I think it might be air leak but that makes as much sense as anything else as it worked fine for hours before install.
Open to any suggestions.
It was 3 wires, white/black/green, which matched the stove colors and works so don't think it's the wiring but that is the only change.
Any help would be greatly appreciated.
Thanks
Long shot - perhaps the motor is not turning in the correct direction, thus not creating enough "vacuum" to operate the vacuum switch.
How would I be able to tell? There a set direction it would be going? Afraid to flip wires to change direction, would it pop the motor?
Mystery solved. Went to look at the direction of the spin, no face plate inside. Forgot to put it back on after cleaning and installing the new fan. Thanks to your long shot I was able to spot it, thank you lol
