Hey all I figured I would start here. I finished building a house and last summer bought the last available non 2020 emissions Summit free standing stoves in my area that I could find.
As I am now past the point of break in and starting to have normal fires I have some questions.
Im single level with a vault in the great room and I figure I probably have 25' of stove vent pipe from top of stove to cap outside.
I feel like the stove while it kicks out some serious heat is tough to damp down. If I start with a small fire to get a nice coal base going things are good. I go to then fill the stove with a few big splits of fir/oak and leave the damper open for just a bit to get things going and get the wood to char. What then seems to happen is once the wood is charred I then go to damp the fire down but its as if I don't get much of any damping effect at halfway or even a quarter of the way and i've just got this raging fire. I can only seem to get a nice lazy burn with the secondaries if I damp the stove down 100%. Maybe this is normal for this stove? It also seems as though the stove goes through wood much quicker than the previous x2 inserts I had at other houses a regency first then the Enviro Kodiak.
My wood is well seasoned and like I said is fir and oak. I have an IR temp gun but question its accuracy as I don't have a stove top stat yet. Last night I tried loading the stove on a small bed of coals and closed the door, damper on H and let it run for a minute or two and I had a raging fire wood was charred. I then damped it down 50% and had virtually no difference in fire intensity and let it run for a bit to see if I would get a change. nothing and the fire was raging. Damped it down to maybe 25% and again nothing. Its not until I completely close the damper 100% that I get the fire to simmer and then get a good secondary burn and fire show.
Is something wrong with this thing? I don't have a stove top thermometer yet. Should be here this evening . ordered one through Midwest hearth as I preferred the color layout to it vs the Condor that has white in the best burn range which seems like it would be difficult to glance at with a white pointer. I do have an IR gun but nothing to compare it too and it gives varying readings often. Last night saw 700 degrees with the damper down at 25%.
What am I doing wrong?
