I need the fan blower (or part number) for an early 24a model Englander. Patient number; D249807. Any help is very appreciated. Thanks in advance! Jim
No problem, there are small ones with the square flange too. Just match up the dimensions.Thank you kindly for the reply. This, darn it, is not the correct blower. The mounting flange on this one is round. Mine is square. My stove appears to be an early 24a model.
post a pic of yours where the blower mountsThank you kindly for the reply. This, darn it, is not the correct blower. The mounting flange on this one is round. Mine is square. My stove appears to be an early 24a model.
including dimensions for the hole and mounting screw spacingpost a pic of yours where the blower mounts
Hi Matt! Thanks for the reply. Mine mounts on the rear lower left. It's a square opening, the gasket is there and there are holes for bolts. I have the original fan, but it's kaput! There are NO numbers on it anywhere! I'll take pics tomorrow and attempt to post. Thanks again for your input. JimDoes it bolt into a heat shield or the heavy plate of the stove? If it’s the heat shield, you may need to drill some mounting holes.
Good idea! I'll take pics, measurements and post tomorrow. Good Lord willing. Thanks for your input! Jimincluding dimensions for the hole and mounting screw spacing
I plan on doing just that tomorrow! Thank you for helping!post a pic of yours where the blower mounts
I will attempt to post pics and measurements tomorrow. Thank you in advance! JimNo problem, there are small ones with the square flange too. Just match up the dimensions.
The Grainger catalog has more detailed specs.![]()
Blower Motor, Psc 115V, 50/60Hz, Rpm 2720/3120 | 1Tdp7 Replacement | Dayton
Buy Blower Motor, Psc 115V, 50/60Hz, Rpm 2720/3120 by Dayton. Replaces OEM: 1Tdp7. Fast shipping on quality HVAC parts. SKU: Dayton.total-hearth.com
Grainger ITDP7
Grainger IDPT5
It's on my 'to do' list for tomorrow. Thanks!post a pic of yours where the blower mounts
![[Hearth.com] Englander Parts [Hearth.com] Englander Parts](https://www.hearth.com/talk/data/attachments/343/343894-4d258452555d007fd93cac3232f0506b.jpg?hash=Nc-lLIBIC2)
![[Hearth.com] Englander Parts [Hearth.com] Englander Parts](https://www.hearth.com/talk/data/attachments/343/343895-ff87ab3e46fed83e8217f3529f3174ca.jpg?hash=t9BO3_YLN9)
![[Hearth.com] Englander Parts [Hearth.com] Englander Parts](https://www.hearth.com/talk/data/attachments/343/343896-7fce2a27901e326eae950000669e4c96.jpg?hash=nG8lU0ups4)
