Hi all, I've been absent around here for while but now I need help. My pc45 won't ignite. I figured the air pump went out and burned up the igniter but I hot wired it and it works and the igniter ohms to about 40(a little weak but ok). The pump doesn't run (or igniter) when it calls for heat. I can light it manually and it runs fine. The fuse is good just no power to the ignition system. Vac switch checks out. Is this a board issue? I haven't ohmed any of the feed wires but it worked when I shut it off and now nothing. It was unplugged until I tried a couple days ago, so I don't think it was lightning struck.
![[Hearth.com] PC45 - no power to air pump or igniter [Hearth.com] PC45 - no power to air pump or igniter](/talk/proxy.php?image=http%3A%2F%2Fwww.freesmileys.org%2Fsmileys%2Fsmiley-love020.gif&hash=57ced075a4a53dcd13d2b552a67328a9)
![[Hearth.com] PC45 - no power to air pump or igniter [Hearth.com] PC45 - no power to air pump or igniter](https://www.hearth.com/talk/data/attachments/108/108645-5914ecc11ca353746e80612d446eccd2.jpg?hash=YfKDTXne3T)
