Just installed a Pacific Energy Summit a couple of days ago and wanted to share my impressions. It replaced a late 70s/early 80s Garrison stove.
Overall, really pleased with the swap. The Garrison was a bit of a pig: it would eat whatever you fed it and put out fast heat. The PE is much more civilized. Starting it up is a slower process, you can't just open up the air intake and turn it into a blast furnace like you could with the Garrison. It also takes more time to get it to the point where it is putting heat out, but once up to operating temperature it is way more consistent in heat output and way more efficient.
To sum up:
Huge glass door is awesome.
Easy to get a consistent burn that puts out even heat.
Burns more efficiently-it creates really light and puffy ash, not much of anything left over after burn. Pretty clear smoke out the chimney. I am stocking it less and not getting the temperature swings I did with the older stove.
Nice sized fire box.
Bad so far:
Door gasket started to fall off after first burn. Looks like a pain to replace as it is held in place with a high temp adhesive. Will attempt to get this fixed through the dealer.
To sum up:
Bad so far:
