Trying to get the build-up off the burn pot can be a real task at times. I have used a wire brush attachment in a drill, used a sanding disc on a grinder, the regular scraping method that I'm sure you are all familiar with and lately have been using water and really rough somewhat waterproof sandpaper to get it really clean. If I had a glass bead cabinet,that would be my choice though the roughened surface would probably coat up again even easier.
After all of this,I'm not really sure that my burn pot is stainless steel or not. Would it matter if it was steel or stainless anyways in regards to the stuff sticking to it and how hard it is to get off? Would a chrome surface do the job? Has anyone seen a chrome burn-pot? This must be a "burning question" for any company designing a pellet stove. The holes aren't plugged up-maybe I'm just being way too clean.
I read an earlier post on the topic of clinkers and that cleaning out the space under the burn pot holder may help that-will give that a go. I don't get them much but would like to stay ahead of the problem.
