Hi, and hope I am in the right place. Have had this Englander 1500 sqft pellet stove for about 6 years now. I believe it is a 55-SHP10 although I cannot make out the model to be sure.
I actually have two problems. The igniter does not work, which I have got by with using a gel to ignite it in the time being, and the feeder feeds way too fast. It actually seems to feed at the same amount regardless of the heat setting. I set to 1 and the fire is blazing through the whole burn pot, and setting it to 9 does the same. It does burn all the pellets, but does so at a level of 9 regardless of the setting.
When I first bought the stove, a 1 setting would burn pretty low and put out a good warm heat, and 9 would send you out of the room.
I do clean my stove very often and have burned the same type of pellets. My cleaning routine has me cleaning the exhaust pipe once per month, the pot after every burn, and behind the back plate once per month.
I wonder if my issue could be linked to the igniter, or perhaps the control board is bad which is why the igniter and the feed speed is not right?
If anyone has any insight, I would greatly appreciate it.
