Hi Folks,
I was running my pellet stove (Quadra Fire Classic Bay 1200) last night and noticed a couple of things:
1) Smoke on Start-up: When the stove first fires up, obviously it creates some smoke in the chamber. It actually gets quite smokey in there for about 5-10 seconds. What I noticed was that near the end of that 5-10 seconds (where its pretty smokey in the chamber), I get a little (and I do mean just the little) whisp of smoke out of the stove. It's so slight that I can't even figure out where it's coming from...It's just enough to barely smell and see. I also have a smoke detector and CO detector near the stove which never goes off it's such a small amount (and this is in a basement with little air movement). My question is...is this normal? It only happens at the peak of smokey start-up. My concern comes around based on my last post:
That post
Is this something that I should be concerned with? I'll keep looking to see if I can see where it's coming from, but since it's such a small amount...it's hard to see. I'm mostly concerned with CO...if this is indicating a leak somewhere (maybe in the stove pipe), I don't want to be pumping CO into the room.
2) The Fan Speed: This stove has 3 heat settings (H/M/L), which from what I can tell just adjustes the auger speed/feed. It also has 2 convection blower settings H/L. The manual states that this allows 6 different settings (2 speed on each of the 3 heat outputs). On the High heat setting, this is VERY noticable. Low speed fan is pretty quiet, and High speed goes up in volume noticable, however, on Medium and Low heat settings...I can't hear/feel any difference in the blower speed at all. Is this normal...or is there something wrong with my fans and/or control box?
Thanks in advance!
JP
That post
Thanks in advance!
JP
