Wood Stove Fan Cost of Ownership
astcroix07
1
Owen Sound
Full disclosure - I work with Ecofan, so take this with whatever grain of salt that deserves. But this is a topic that comes up a lot and I think the actual math is more interesting than either "these things are a scam" or "these things are magic," so wanted to share it straight.
Cost of ownership on a stove fan really comes down to two things: how often you're replacing the motor/fan itself, and what it's saving you on wood. On ours, the motor's rated for about 4-5 seasons of regular use and it's a $25 kit to swap when it does go, versus a lot of the budget options where the whole fan is more like a 1-2 season part and you're just buying a new one. Do that math over 10 years and the total spend looks pretty different even though the shelf price at the stores or wherever looks backwards.
On fuel savings — University of Waterloo in Ontario, Canada did an independent study, landed around 12-18% depending on the model or 16% average. Take the price of a cord of wood, multiply it by how many you burn in a year, then multiply that by the % of wood savings your Ecofan model claims. For an Ecofan UltrAir, I've used 3 cords of wood a year x $300 each x 0.14 and it's $126 per year, meaning your UltrAir pays for itself in 1 year, 4months. These calculations were done with CAD pricing. Our newer AirDeco models have a lower start temperature, a higher CFM and even higher cost savings over time.
Here is the the study details if anyone wants them from the University, and if you want to run your own numbers based on your stove/wood costs there's a calculator on our site. Not trying to turn this into an ad, just find the "cheap now vs. pay once" framing gets skipped over a lot in these threads and we find some other fans on the market cannot back up their performance claims with data like this.
I got the original Ecofan (max?) when it first came out around 2000 or so. Since then, I've owned a few China fans. The Ecofan definitely lasted the longest. I had it on 3 different stoves. Eventually, it slowed down too much after about 9 years. The Chinese fans have lasted 3-5 yrs. each.
One point to note: at least one of the knockoffs moved significantly more air. I could put a candle in front of the Ecofan and the flame just wavered. When I put it in front of the VonHaus fan, it blew the flame out when closer than about 15".
I love that Caframo is now providing rebuild parts. That is definitely good news. They were not available years ago when I had the original Ecofan or I would have considered this option. Note that the motor replacement is $35 USD.
Reactions: Todd
My stove room has a ceiling fan, it was in the home when we moved in 32 years ago. It runs continuously when the stove is burning all winter, we run it in warmer weather when the AC is off which isn't much.
Reactions: Todd and stoveliker
I have the vodafan version of the ecofan, cost $35 from Amazon in 2022 and still works as good as new.
My Vodafan eventually slowed down. Too bad, that was the one that moved the most air.
This is useful info. I had a Dutchwest stove that did not have a fan but just this year purchased a stove with a fan. Had no clue how long they run before they need to be replaced. Thanks.
hm. My Sonyabecca cheapo (chinesium?) Amazon fan is still going strong - since 2019.
I wonder if it matters (for lifetime) that it has a safety bimetallic "lift-off" under the fan: get it too hot and the bimetallic strip will lift the base of the fan off the stove, protecting at least the thermoelectric element from too much heat. Not likely an issue for the motor, but that's going fine too, so far.
Though I don't see any difference in heat distribution in the stove room (large basement) - possibly due to the low ceiling and the fact that I'm pushing the heat up the stairs anyway with a cold air fan ducting living room colder air onto the floor of the basement.
For me, I've found that a small cheap desk fan has 10x the CFM for 1/2 the price, and lasts for years (even factoring in electric usage, it stays cheaper for over 5 years of continuous running through a 5 month heating season). I realize it's not apples to apples if someone really wants a thermoelectric fan, and if you're in a situation where you just need that slight boost in CFM maybe it can fill a niche, but to me it just doesn't seem like the right tool for the task if the goal is to move warm air around the house. Granted I don't think I tried an ecofan, but I switched from a stovetop fan to a desk fan pretty quickly, and found a noticeable difference in heat distribution.
We dry our towels over the woodstove and of course at least once a year a towel will catch one of my 2 cheap heat power fans and knock it down onto the brick or fire mat on the floor. They usually survive but one seems to be slower and the other sounds like the bearing is getting bad.
I'd be pretty bummed if i paid $150 or so for each. At around $20 for my cheap ones i'm not as disappointed in my towel control.
But i agree the small table fan on the floor on low speed pushes so so much more than any eco type fan that that's the must have fan.
The eco types are more for fun and a quite little push. (Silence is their Greatest Strength.) And that's why i have them. Sometimes i just have to turn the electric fan off even thought it's not even that loud, but still loud enough for me to turn it off.
