F4jock
But that's where your wrong. A Mt Vernon freestanding stove is not going to throw any more noticeable heat than an insert .
That isn't what I said. What I said was that a freestanding will radiate heat in more directions.
Just the exhaust stream. And measured by carbon monoxide, as a proxy for particulate matter. Cleanliness inside stove was partly assessed through visibility of the glass - and maintanence of burn pot.Hey guys maybe a stupid question here but what does "cleanliness"mean exactly? How dirty the inside of the stove becomes or its exhaust?
Carbon monoxide, a gas, is a proxy for particulates, a solid? Exhaust gas composition is indicative of combustion efficiency, not cleanliness unless you choose to define / equate gaseous emissions with cleanliness and ignore particulates.Just the exhaust stream. And measured by carbon monoxide, as a proxy for particulate matter. Cleanliness inside stove was partly assessed through visibility of the glass - and maintanence of burn pot.
Its bit more complicated in wood stove testing, where the tail end of the burn will have high CO and low PM. But for much of the burn, CO and PM will track each other. In a pellet stove, its easier, as its a steady state burn, so CO and PM act in unison, both being indicators of incomplete combustion. If you want to check out the science behind that, there are some footnotes in the report about CO and PM.Carbon monoxide, a gas, is a proxy for particulates, a solid? Exhaust gas composition is indicative of combustion efficiency, not cleanliness unless you choose to define / equate gaseous emissions with cleanliness and ignore particulates.
So you contend that the correlation of CO2 to particulates in Guatemalan wood cooking stoves burning whatever-wood is a one-to-one correspondence with a pellet stove in the USA and therefore can be reliably used to predict their particulate emissions? I've been reading several combustion and emissions studies that call that relationship into question.
In short, although you can confidently state the stove-to-stove variance in CO2 emissions you are making quite a leap of logic to use this data to measure particulate "cleanliness."
I'm no engineer, but our testing was developed with input from a bunch of Ph.D.s who have lots of experience testing biomass. Now that the EPA is requiring test labs to test for, and report efficiency and CO, we will slowly see a public database that can show he level of correlation between average CO and average PM. One thing about test lab data is that with PM, you just get to see how much PM is on the filter for however long you left it there - 1 hour, 3 hours, 8 hours. But new equipment that we have used a lot shows instantaneous PM and CO readings in digital format. So you can watch the degree that CO and PM track each other. I'm sure there is a Ph.D. these or two in there about how closely they track each other depending on the type of biomass combustion. So keep researching - and let us know what you find! Its always good to be skeptical and really understand how data is gathered and reported. There are a lot of issues in any test lab and tons of them with PM testings. We didn't have capacity to test PM here in Maryland, but feel confident with our CO results.
Yep Will. I paid nothing and that's about what it's worth.
Before you start demeaning people maybe you should review the scientific method of evaluating mechanical devices like for like and the proper presentation of data. Now I could get snarky like you and posit that while I was taking engineering courses you were apparently enrolled in the Liberal Arts equivalent of "How to insult people who disagree with you" . . . .
If we cannot delete their comment in fact, then simply delete it from our consciousness and move on.
Sadly, after considering it for about a year, following this topic I decided to visit my Preferences and add to my Ignore list, despite the fact that I'll likely miss out on some valuable knowledge.
Not you, LuvMyPellets.
I spent three years starting up PPL's Susquehanna SES 2 and then had to go over to Unit 1 to unscrew what some people who dealt fast and loose with data did to it so yeah Johnny, I know from both nukes and ignorance and their consequences and I have very little tolerance for the latter. In my business lives sometimes depend on getting the details right the first time. I like sleeping at night.While F4 is in fact, quite blunt, gruff, and a tad condescending at times, I feel he is asking valid questions. A guy like F4 is not welcomed everywhere, I get that. But man oh man, if I had him here, in the QA/QC department at my nuke plant, I would be able to KNOW a questioning attitude was being embraced and no one was "sneaking one by".
I think you'd have to weigh the casting of each and realized that the thermal mass capacity is about the sameThat isn't what I said. What I said was that a freestanding will radiate heat in more directions.
I have two stoves, one is an insert. They both radiate pretty much unidirectionally. There is almost no heat comming off the back of my free standing stove because that is where the electronics and motors are located.John, what I meant about the radiant heat is that a free-standing has more heated surfaces and can radiate 360. An insert radiates primarily unidirectionally. This should be really evident under low-fire conditions where the blower is off. No matter how you direct the heat from an insert the lack of radiant surface and the limited psitioning ability is going to gimp it somewhat compared to a free-standing of ostensibly the same BTU output.
Not the top or the top or the sides?I have two stoves, one is an insert. They both radiate pretty much unidirectionally. There is almost no heat comming off the back of my free standing stove because that is where the electronics and motors are located.
I would further question if radiation is a significant mode of heat transfer for a pellet stove. I don't believe temperatures are high enough for significant radiation. The primary means of heat extraction for a pellet stove is through the convection blower.
Just my opinions.
Harvey, I own a P61 and on a cold winters night with it cranking at a moderate burn, sometimes high burn, you back away from it. We have chairs on each side of the stove just outside the tolerance distance and you find yourself leaning away from the stove sides. The paint on the sides of my stove is starting to have a center spot of discolor just like my radiant only all steel coal stove used to do ( though it was more drastic and needed paint periodically). So the P series stoves radiate heat as well as blow by convection.. it's actually one reason I bought this unit over a P52i, I wanted that radiant heat and I get it. Let me put it this way, you aren't putting your hand on it, ok, and you won't find a cat sleeping on top of it LOL, like you might see in some peoples photos.. Primary heat by convection fan , yes that is true but cast stoves and certainly inserts do not radiate like all steel P series Harmans do. I've been to many shops running stoves and you can put your hands right on most of them. They probably are 80-90% convection via blower output.I have two stoves, one is an insert. They both radiate pretty much unidirectionally. There is almost no heat comming off the back of my free standing stove because that is where the electronics and motors are located.
Just my opinions.
What about outsides air kits? Are you running these on all of your test stoves, you should be. This will greatly effect the efficiency and burn of a stove, especially when five stoves are running right next to each other.
