Below is what I have for instructions that came with my Harman XXV. I am drafting at > -.6 in both high and low combustion modes. My magnohelic stops at .6 unfortunately, but I am going to borrow one that goes up to -2 this weekend. I turned the pot mentioned below to full CCW to minimize blower voltage, but it is still off the scale. They said not to worry about it at the end of the write up below, but I am wondering if I am burning too much fuel due to the increased draft?
Question, I am planning to hook the fresh air inlet to a pipe and run it about 4ft into the next room through sheetrock for air circulation. Would this help me reduce my draft?
Or, am I sweating the small stuff?
Thanks!
Ed
1. Plug unit into a 120VAC, 60 HZ outlet.
2. Close the hopper lid, front view door, and the ash pan.
Neither pellets or a fire are required for this test.
3. With the mode selector in the "OFF" position, turn
the feed adjuster to "TEST".
4. Record the high draft_____in W.C. (Normal is -.50
to -.60) The control will be on the High Draft for a total
of 2 minutes.
5. After 2 minutes, the combustion motor will go down to
low draft and the distribution blower will go on high. Allow
approximately 15 seconds to pass for the combustion
motor to slow before checking the low draft.
6. If the low draft is between -.35 and -.45, record the
reading _____ in W.C. If the reading is higher, slowly
turn the set screw counter-clockwise until the draft
lowers. If the reading is lower, very slowly turn the set
screw clockwise until the draft increases.
NOTE: The test mode alternates from high to low
draft every 60 seconds. If more time is needed
for draft adjustment, wait until the next low draft
cycle.
NOTE: In some cases, the draft may not go as low
as -.35 to -.45 even with the set screw completely
counter-clockwise, ideally, you should just set it as
low as possible.
Thanks!
Ed
of 2 minutes.
cycle.
low as possible.
