Pellet Trivia
Shaw520
426
Modena
Its been more than rumored that Somersets produce more heat then, (dare I say most) other brands,... I learned that I need to set my feed rate at 3-3 with GS's in order to get comparable output as Somersets with stove set at 1-3... ok no mysteries yet..... but here comes the question.. Why does a hopper full of GS's set at 3-3 last significantly longer (like 2-3 hrs longer), than a hopper full of Somersets set at 1-3,... with all other settings being equal ?
Im starting to wonder that maybe over-all BTU/HR output may be more equal than we think,... just because the Sets are showing higher stove temps and more "felt" heat,... if they burn up quicker than the gains are questionable.
In some things size does matter.....
Compare bag to bag, Does one look puffier than the other? Even though both bags weigh the same. Density also plays a roll.
Reactions: The Ds
Ive actually had issues trying to keep the Sets from burning too hot,.. if I dont turn the feed down, and the convection up I'll get a high heat shut down with the Sets.
So,.... Ive been mixing them with GS's and getting some real nice results.
Not all stoves heat exchange systems are created equal?
Some extract more heat than others...
yes agreed,.. but I think I'm referring more to feed rates.
Well the difference between GS's and Somersets in my Quad or Fahrenheit is HUGE!! Not a little difference. A huge difference.
The difference in my CPM between any pellet burned? Not so much. That's the difference between a Tube type heat exchange system and a convection type heat exchange system.
Yes. Pellets matter. But the heat exchanger helps a lot.
I have the same Issue when I burn GS and Stove Chows the Chows burn hotter but they last 3-4 hours less. But I think they are smaller. When I fill the hopper with a bag they take up less space
If they take up less room they are also more dense. Adds more fuel to the fire. Lower the feed rate to even out the burn length. Unless its cold out and you need more heat fast!
We like pellets that are dense and stuff the burnpot with fuel on colder days. If the stoves on a stat it will just get the temp in the room up quicker and shut down the stove that much faster. Stat is the best pellet equalizer there is IMHO. Remember you can only turn your stove up so high. If your cold with a less dense pellet and you need more heat? Change your fuel and let her ripe. A super charger for your stove and its freakin free even! Well as long as the pellets are the same price, In this case sets and GS being boxstore stuff they should be.
Reactions: glenc0322
I've never burned any, but I just picked up 5 bags to try. The first thing I noticed is there is a lot of slop in the bag, like they're not completely full. Not as easy to carry as a fuller bag.
Put the bag on an accurate scale....if it's very close to 40, then it's all about the density.
