I bought a used EF 2 insert that has worked fine but jammed yesterday. I thought perhaps a gear had stripped so pulled it apart checked and lubed the gears, reassembled it and everything worked freely while empty. I loaded pellets and ran the stove for 5-10 minutes when I could hear it binding again and smelled something like hot electrical wires. It quit feeding and today I found it had burned out the motor. The auger was jammed absolutely tight. After wiggling it back and forth enough to get the pellets out and turning freely by hand again, I threw in a handful of pellets and it promptly jammed. All it takes is 3 or 4 pellets to make it bind. It appears the auger is so worn (bushing OK) that a pellet will get caught vertically behind the auger which starts picking it up until it gets up about 1 1/2 " where the auger is not worn as bad and the clearance is less and if the pellet doesn't break, stops the auger. If I put pellets in above where they can get behind the auger, it seems to function fine and raises the pellets no problem. This bag of pellets appear harder and longer than the ones I used before, therefore harder to break, which may be why I never had the problem before.
I'm wondering if anyone else has experienced and solved this problem?? I hate to spend at least couple hundred bucks for a new auger and motor and not have it work. I'm considering building (welding) up the edges of the screw for the first 3 inches where the maximum wear is to see if it stops the jams.
Any thoughts appreciated.
Thanks,
Smiley
Thanks,
Smiley
![[Hearth.com] Pellets binding EF 2 auger -- burned up motor [Hearth.com] Pellets binding EF 2 auger -- burned up motor](https://www.hearth.com/talk/data/attachments/126/126727-b52c277892f013784e35784cafe0fe0d.jpg?hash=c907J02NJn)
![[Hearth.com] Pellets binding EF 2 auger -- burned up motor [Hearth.com] Pellets binding EF 2 auger -- burned up motor](https://www.hearth.com/talk/data/attachments/126/126728-6f3728398eb55929bc8a9a09f0dafc8f.jpg?hash=b68TiZdrfu)
![[Hearth.com] Pellets binding EF 2 auger -- burned up motor [Hearth.com] Pellets binding EF 2 auger -- burned up motor](https://www.hearth.com/talk/data/attachments/126/126729-25a2aa45cfe5af51274572d8671e10f7.jpg?hash=j9ZMFp6NlD)
