PelPro P130 not doing anything?
tommyboy1979
5
Maine
I just got a PelPro P130, first time starting it, did priming sequence -the off/high/off/high sequence to start, no noise, no pellets dropping, nothing but a blinking green light, and nothing else, any suggestions?
johneh
4,762
Eastern Ontario
Do you have a manual?
If so did you start it the way the manual says
did the auger run for approx 2 min?
Unplug the stove and do the priming again listen
for the auger motor
If you hear the auger let the stove run for a least 20 min to see if pellets drop and the fire starts
tommyboy1979
5
Maine
for the auger motor
I actually fixed it. I guess in the process of moving it into position on the hearth some wires came loose from the heating dial on the side, when I opened it it was plugged in but crooked, once I plugged it back in the whole way it fired right up. Hopefully, this can help someone with the same issue down the line.
