Pelpro PP130B auger motor spinning
Josh379
3
Northern maine
I bought this stove around the first of the year and now got around to hooking it up. It took 3 times of the initial start up instructions to light but it did. It wasn’t feeding very hard. And started going out. But no codes or blinking lights came on. I re started it. Still no feed at all. I took side panel off of it to find the auger unplugged. So re started it again. The motor worked but was spinning counter clockwise and auger wasn’t turning. It was wrapping the wires around it. I grabbed it and held it still and the auger began to turn. The stove worked great. Now I’m trying to figure out how to solve this issue. Does anyone have insight on this. I looked everywhere and can’t find where it says there’s a bracket for this motor. Replacement instructions say pull the pin unplug and take out. Thanks in advance
There are 2 bolts that hold the feed motor assembly in place. But that’s not the motor. That’s the whole auger and tube. From what I’m reading everywhere else you pull cotter pin and unplug motor and pull it out. So I’m not sure what to do. I have a piece of wood zip tied in under motor to keep it from turning. It’s working great now. Still like to figure out the right solution
looking at some images of the motor set up its screwed/bolted to the bottom plate that mounts everything to the stove... if its a new stove i would be calling for warranty... Zip tying a pc of wood to it is not the safest thing in the world
It doesn’t. And it doesn’t get warm anywheres near it. I held the motor for a long time. No heat there. I’ve been trying to get ahold of customer service so we’ll see from there. Was just wondering if anyone had experienced or knows the problem I am. Thanks for your time
Hello
I recently replaced an auger feed motor in that stove. The new motor comes with a much thicker and stronger hitch pin. I also took some pics after I got it working. I believe these motors may reverse if the pellets jam up. This may explain your problem. Hope this helps.
  • [Hearth.com] Pelpro PP130B auger motor spinning
