The small locust pile I have was actually cut late fall of '13.
I do clearly understand about seasoned wood.
I'm not installing it for about a year. Meaning next spring I should be ready to install.
I might buy some wood this spring only as a back up to have on hand so there is no rush to downing the trees, as I have to have someone else do that.
Now some things I have to be clear about, I have some limitations, & I know what they are
Simply stated: ...Size matters.
Some of you may not think handling 16" splits is a big deal.
If you're male, your probably a foot taller than me & twice my weight.
I'm 5'1" & slightly over 100lbs, and gutting houses & remodeling has taught me where my limits are.
I'd rather take the time to cut to 12", or maybe even 10" if that means it is easier for me to lug around back & forth on a regular basis.
This is something I have already factored in.
My stove won't be my primary heat, so I am not as concerned with long over night burns.
What is nice, for me at least, is that the size of wood required for most of the small stoves actually works for me.
And also, now with the higher efficiency, I can still get a decent amount of heat out of a stove that requires smaller splits.
The bigger issue will be trying to convince my pooch that those wood piles are not treats for her, & figuring out a way to train her to bring me some firewood. She has zero issue handling 16" splits--& jaws of steel to whittle them down LOL. But seriously, I might get her a doggie backpack to carry some into the house.
