Piazzetta Marcella Frustration - none responsive control panel?
ccmasrc
1
New Hampshire
I have a Piazzetta Marcella 2 seasons old...This will be season 3
The time line of issue:
2 weeks ago went to fire it up for the first time this season.
Display looked normal, but the power button would not turn it on.
Read in a post.. (not here) that unplugging the control panel and re-plugging might fix it
(basically checking its connection). I did this, and.....
The stove panel went into complete hieroglyphics.
The dealer.. over the phone.. (because they cant service it until December)
said replace the control panel because it was fried
did that... same problem.
the dealer said replace the control board main computer because it was fried
the dealer suggested replacing the data cable because I might have damaged it
did that... same problem!
Insert face palm here! $500.00 in parts so far.
Any help would be great from anyone who knows these beasts.
Thanks
Reactions: atsiem
Well if the control boards are new and you are still getting hieroglyphics then start looking at wires, power supply, short circuits, anything electrical.
Start by measuring the electricity from the outlet that feeds the stove. Is the stove on a surge protector? Any surges lately?
Then look at the wires, connections, and such. in the stove. Start by gently wiggling and pulling on the wires to make sure they are well connected. Then look up the stove wiring diagram and get acquainted. You may have to start testing circuits.
You already fired the parts cannon at it, so try the simple and cheap diagnostics now.
Good luck.
Reactions: ccmasrc
Thanks
@ccmasrc Did you ever resolve this? I have a similar experience. Garbled running from a Delta Ecoflow Pro battery, and dimly lit running from a Honda EU2200 battery. (The cabin is off-grid.)
Voltage readings may be causing it...
- EcoFlow: about 55 V on one conductor and 65 V on the other, to ground.
- Honda EU2200i: about 65 V on both conductors, to ground.
- Hot-to-neutral under load at the stove plug has not been measured yet. (replacing igniter)
[Hearth.com] Piazzetta Marcella Frustration - none responsive control panel?
