I have a 15 year old vent free Monessen DFX32NV that has worked flawlessly all these years but now I can't get the pilot to stay lit. It will ignite with the push button, but even after a minute of holding in the pilot switch it pops back out and pilot dies.
I found someone else on the forum that had a similar problem and I did some testing based on that info. First off I want to make sure I understand the terminology. There are 2 wires coming from the large black rod on the igniter assy, which I believe is the ODS. When I measure across them, with a pilot flame, I get over 300mv. There is also a brown wire coming from a post that sticks up into the pilot flame and it goes to a fitting on the rear of the valve assy. If I measure between this and TH 3 on the terminal block I get about 130mv.
I am somewhat confused about what each sensor does. I think the voltage from the brown lead keeps the gas valve open, as long as there is a pilot flame, and the ODS somehow detects a lack of sufficient oxygen and closes the valve. Based on the other post I believe I am getting correct voltages to the valve, but it's just not opening to allow the burner to come on. This leads me to believe the valve assy is probably defective, but I really don't want to invest over $200 if it is not. Any guidance is greatly appreciated.
