Hi all,
New member here. I had two Pin Oaks cut down recently. One was standing dead and the other was dying of some sort of root rot. To make things worse, the top of it started falling down and crushed a bunch of toys in the backyard along with a metal table.
So I'm starting to think about getting a high efficiency fireplace or a wood stove in the future and starting to split the oak that was cut up (since it takes time to season). To my surprise, I really like splitting wood! I got one of those Fiskars super splitters that I've seen recommended and it works great. Most of the oak splits apart nicely and flies to either side now that I have the hang of it.
I have one problem - one of the rounds was about 2-3 feet. After a rain, I tried to split it and it sorta spit back at me and laughed. That's how wet it was. I let it dry a bit and then I was able to split off the outer portion. I'm left with an inner portion which has some sort of branch stubs sticking out of it. I'm able to bite into it with the Fiskars but it keeps holding together. I was able to chop up a similar sized round so I wonder if there is something special about this one.
Should I set it aside to dry out some more? Do those branch stubs mean that it is extra dense?
Thanks,
Louie
Thanks,
Louie
Then I started hacking away. After a few whacks, part of it split off. I kept doing that and it turned into about 5-6 pieces.
