hi all, I've just bought a house in upstate NY and would like to put a wood burning stove in. I'm not clear about the chimney system. It's a single story ranch house with a metal roof.
First question is should i go though the wall or the ceiling? I'm planning to put the stove in the living room which has an outside wall and I'm happy to space the stove 18 to 24" from the wall so i was thinking single wall pipe on the inside.
Looking at the cost of the Duravent stuff, it seems the pipe will end up costing more than the stove (which i'll buy second hand), so I'm guessing through the ceiling/roof will be cheaper since doesn't need the Tee and all the other stuff and the double wall section will be sorter. Is that correct?
I know I should use an air intake pipe to feed the stove with outside air to avoid sucking cold air into the house. does that air intake pipe need to be anything special? will single wall be ok. should it be 4 or 6"
Also, i'm thinking a lot of heat will go straight out the chimney with a though the roof chimney. Is it ok to put a ceiling fan above the stove to help circulate the hot air more efficiently?
thanks
thanks
