Hi all, I'm new here and have been rebuilding a classic Lopi Spirit stove. It will be used with LP and I have done the conversion with all new parts. Here is the problem:
With the gas turned on, I turn the gas valve from OFF to START and push in the valve to light the pilot light. The amount of gas that comes out is so extreme it won't light!! If I let the START button out and then push the igniter it will light but soon dwindles out. This is damn scary as Im fearing some kind of explosion. I've been using other LP stoves for years without such a blast of gas coming out during starting. Any ideas whats happening?
FYI, I am hooked up to a standard bar-b-que tank for this testing for which Lopi said was OK. Might there e more pressure in one of these tanks than in a standard household line?
Thanks!!
Dave
Thanks!!
Dave
)) Geez these are the kind of stupid mistakes that turn people into charcoal briquettes! Thanks for checking in and after I get the pressure regulated I will let you know if it worked.
