Hi all, newby 1st post
. I have an Invicta Wood burning stove, which has been in use for about 5 or 6 years. Very very like this one: (broken image removed)
Just a different pattern on the glass of mine.
The flue pipe gos from the rear through 90 and up an exposed black pipe, which inside the chimney connects to a flexi-pipe on top of which sits a 'chappeau-chinnoise' - chinese hat type rain cover.
In the early days we had a small but worrying fire in the flue. Learnt quickly that the issue was my burning the left over pine floorboarding as kindling & the sap stuff igniting in the pipe. Or at least that was what we were told....
So since have made my own kindling from the oak/chestnut logs I burn. no problems since on that score.
We do get quite a lot of soot and stuff tumbling down the flue though. Every 2 - 3 days I remove the baffle & clear about, say 4 or 5 tablespoons in quantity.
More recently I saw on Amazon a Stove Thermometer, the ones that magnetically stick onto the flue & tell you if it is at 'optimum' temperarture. 200-300
Well mine arrived and I have used it. Last night a great fire, a cosy 22.5
in the room, but the thermometer read 150
and gradually got cooler as I let the fire die back. According to the thermometer at that temp I am creating 'creosote' - so not good. However I reckon that if I could get my stove upto 200+
the room temp would be in the 30's
I have seen friends with more expensive stoves, Villagers for example & these really roar and draw hard, I've seen some even glow red-hot - 'single skin type'. Mine is the type with a double which draws cool air underneath, then 'sucks' it through a series of chambers ( like a car silencer) but heats the air which is then 'blown' out of vents on the top. It draws gently.
So, just wondering if am I running my stove incorrectly, or is my stove not compatible with one of these thermometers?
Sorry for the long post.... all suggestions welcomed
. I have an Invicta Wood burning stove, which has been in use for about 5 or 6 years. Very very like this one: (broken image removed)Just a different pattern on the glass of mine.
.Well mine arrived and I have used it. Last night a great fire, a cosy 22.5
.I have seen friends with more expensive stoves, Villagers for example & these really roar and draw hard, I've seen some even glow red-hot - 'single skin type'. Mine is the type with a double which draws cool air underneath, then 'sucks' it through a series of chambers ( like a car silencer) but heats the air which is then 'blown' out of vents on the top. It draws gently.
. Even so it heats a large-ish room and the bedrooms if doors open well.
it at home and stack it.
