Hey guys,
I have my 9 year old Poulan Pro 295 that has always performed well, but it the last couple weeks it has been heading downhill. First the throttle started sticking last weekend. I babied it to get the work done, but if was making a long cut, when I pulled out it would keep running for a second.
Any way, I took the saw out today (forgot to fix the throttle issue) and when I did the saw would idle fine, but as I would trigger the saw, it would take off and run extremely fast. I made a couple cuts but decided so I took it back to my shop to look at.
I did a quick once through and didn't notice anything. Plug looks ok, air filter is clean, the gas was new today. As a side note, I did wd-40 the carb linkage/cable so hopefully that is taken care of.
Any ideas of where to start. What would cause a saw to go from running good to screaming like a banshee overnight?
Thanks
Thanks
