It finally happened. I have absolutely no provisions for this event. I have talked about it, read about it, designed it for others, but done nothing on my system.
I went to bed early last night, about 10:00 p.m. because of a busy day today. We are pouring a slab for a masonry heater, concrete @ 8:00 am. Any way at 11, I hear the alarm beeping because the power failed. I loaded the boiler full before bed, so the boiler was cranking when the power went out. When I got into the boiler room with my flashlight (the battery emergency backup light is on the floor, not installed) the boiler supply was at 230, the return was @ 210. System pressure was @ 25 PSI. I hung around for a while, things appeared stable so I went back to bed.
At 3:00 I woke up to a funny smell. Still no power. Both temp. gauges were over scale, they max. out @ 245. I thought that I should get some feed water in to the system, so I filled a bucket from the drain to let some hot water out. Eventually the pressure started to drop to get down to the fill pressure @ 20. Then the boiler blowoff pops. Sprays the boiler room with water and fills it with steam. I was splattered, pretty wet, but not burned. Had to be a pretty funny scene, from the outside, I was in my pajamas.
Now the primary loop temp. gauge was reading cool, there was no water in the pipe. I could hear water popping in the boiler, then it blew again.
That lasted another 5 seconds, and I thought that I had to get some water into the boiler. I got some hoses and connected the boiler drain up to the slop sink faucet. The trick here was to have a female-female hose connector. I did. Then I slowly bled cold water into the bottom of the boiler. The system pressure started to go up so I connected the primary loop drain to a hose and put in in the sink to drain. I balanced the flow so the system pressure stabilized and the boiler temp. started to drop.
When the boiler got down to 150, I shut off the water. The system was stable, so I prepared for a power up, killed the house main CB and went back to bed. At 6:00 I switched on the main house CB and everything came to life. I opened up the air and the boiler fired right up from fuel still inside. Damage? so far some insulation melted off the pipes, thats it. I am lucky !
What can I say that I learned from this event? I just confirmed Murphy's law- If it Can happen, it Will happen. ( and it did)
I have to plan for the next event like this, and installing the emergency light isn't a bad idea either.
