Hello all,
First, thanks to all of you knowledgable folks for helping educate this "fire dummy". I have been reading posts on these boards for what seems like a long time now, and I haven't seen an answer to my question, so here goes:
I have a prefab "Preway" fireplace that I will be ripping out to replace with a new freestanding wood stove. We plan to use this stove to supplement our electric heat for about 1700sf of living space. The rip out and hearth build will be the easy part. (It will not be an alcove install thank goodness!) I am really concerned with the chimney!
The existing chimney is a triple wall pipe 8" inside 11.5" inside 13", that is enclosed by a framed chase from ground level up to the roof. The height of the chimney is 19' (not counting the below grade part). I know I cannot use the current flue as is for the new stove. But is it OK to just simply reline with insulated flex? I cannot find any "clearance to combustibles" specs on flex liners. Assuming the stick built chase is in contact with the outer pipe (13" O.D.) I will have 2". Is this safe? I'm not totally against ripping the entire chase down and running Class A all the way up, but that's alot of work if I don't have to...
I just want to make sure it will be safe.
Thanks for the help,
Jason
Jason
