I'm swapping out a natural gas hot water heater for an indirect, as the NG heater doesn't have enough stack to make any real draft, and we're getting blowback into the basement. (see the photo below for the installation).
The boiler has five zones currently, so we'll be adding a sixth zone with DHW priority.
I just got a quote for the following:
SuperStor 80 gallon indirect (double coil setup, so I have the option to plumb in solar later)
Install sixth zone valve
All necessary plumbing
Clean up old setup, remove tank, etc.
Cost was around $5200.
Seems a bit high, since I've seen pricing on the indirect tank itself for just under $3K. Zone valve is $300 or so, miscellaneous plumbing parts is a couple of hundred. Labor in the range of $2K for this job?
Seems a bit high, but maybe I'm cheap.
Thoughts?
Lee
![[Hearth.com] Price for installing an indirect water heater? [Hearth.com] Price for installing an indirect water heater?](https://www.hearth.com/talk/data/attachments/226/226485-f41b8bda9c59537a674b411b1362c4fe.jpg?hash=g1ZIdmhdwE)
Thoughts?
Lee
