From jotul website:
AIR!
The wood is utilised in the best way when the draught control is fully open and the flames are intense. That will also reduce pollution, because gas particles are combusted and produce heat instead. Once your home is warm, the temperature is regulated by the amount of wood, not the air control.
OVERNIGHT HEATING
Very few wood stoves can burn longer than two to three hours on one wood load. The old way of closing the air supply so that the coals will smoulder overnight is a source of pollution and creates the risk of a chimney fire. In addition, the heat benefit is poor as the gases are not combusted and the energy is not utilised. The last wood load in the evening should be some bigger hardwood logs that burn as normal with the air vents open. Even if the fire dies out, the insulation in the house will keep the heat in. The stove and chimney will still be warm in the morning and it is no problem to get the fire going again.
My question is this- if I’m supposed to leave the air supply wide open all the time, why have it at all? It seems to me that I’ll be more wood efficient if I turn it down even a small bit overnight.
Any thoughts?
AIR!
OVERNIGHT HEATING
Any thoughts?
