There ought to be a straightforward formula relating quantity of air required (primary and secondary air) to burn a quantity or BTU rate of wood. Anyone know where I might find a reference?
I'm in the middle of hacking a homemade wood furnace that will use forced air for combustion, via a small variable speed fan (or two - still experimenting). So far I have had some pretty good experiments out in the driveway, using pretty crude fans (hair dryers and heat guns) to simulate a permanent and controlled forced air draft, and am able to achieve completely clear, smokeless chimney exhaust after much fiddling. I'm probably way-overdoing it on air flow, and would like to order some fans with known CFM ratings.
These experiments started with Rocket Stoves built out of 1 gallon empty paint cans, very successful after some adjustments, then scaled up to 5 gallon metal tins, now scaled up to 50 gallon drums. But, no, this isn't a "barrel stove" - Sotz used to sell those and everybody called them "Sootz". It employs several features which should increase efficiency, such as preheated combustion air, secondary combustion, insulated firebox and so on. Great fun, and it isn't costing $10,000 for an outdoor wood furnace. Sure, it will have to be rebuilt in a few years when it rusts out, and that's just more fun that I can anticipate.
So where might I find info about airflow rates for wood combustion (and other wood-burning physics)?
