As some of you know, I'm a new owner of a Quadradfire Castille Instert Pellet Stove. I'm now getting a chance to run it through it's cycles cause the weather has cooled down. I have had the following problem with the stove since it's installation. When ever I start my stove, it goes through a start up cycle. I start the stove by moving the thermostat up. It goes through it's 5-10 min. start up where it feeds pellets and gets the stove going. No problems so far... However, when the fan kicks on it no longer feeds pellets and the stove goes out even though the red call light is on. To correct this I move the thermostat to off and back on -- then no problems from there on until it reaches it's thermostat temp. Once the stove goes off because of reaching the thermostat temp. and cools down, it starts up only to fail agian when the fan goes on. Then I have to put the thermostat to off and on again. Then the stove runs great! Yes the red call light is still on.  Yes the fire pot is closed & clean. The fire pot is a tricky thing to get closed! This has happened every time the stove has cooled down. It starts, but will not continue once the fan goes on. I tested it this past weekend if it would re-start if the stove was warm. Yes it does. The room met the thermostat reading, and the stove shut down. I then opened the outside door to to cool the room. The stove started with no problem. Again the stove was still warm, although it did go through it's shut down cycle and was completly off.  If I am not clear on this please let me know. I'm not really savy with all the terminology yet. I'm hoping someone else has had this and found a solution because the marketing materials say it should come on when the thermostat calls for heat. I do appreciate your thoughts!
Thanks!
Beth
			Thanks!
Beth
