A little background. I have a 2007 Quadrafire Castile FS stove. Two years ago I had to replace the control box and since that time it would operate erratically, if would fail to start from time to time
. This year I took it out on my deck took it all apart and used a vacuum and air compressor to clean it up. I also tightened up all the electrical connections. I put it back in and it will operate flawlessly during the day, but in the morning when it starts up it will heat the room part way and then shut down. The thermostat is still calling for heat and the red light in the stove is on. I can push the reset button on the back of the stove and it will start up and run. I'm wondering if the snap disc on the drop tube is faulty and after the stove runs for an extended period that it snaps. I'm not at home right now, but the snap disk that I'm referring to is not the one that I can push the reset on by the auger motor. There are heat insulated wires that go into the stove up by the auger motor that I think hook up to a snap disc. When the stove does shut down like this you always have to push the reset button on the back of the stove to get it to start again.
Also, can someone give me a run down on what the different color lights mean on the control box.
Thanks,
Bob
Thanks,
Bob
![[Hearth.com] Problem with Quadrafire Castile operation? [Hearth.com] Problem with Quadrafire Castile operation?](https://www.hearth.com/talk/data/attachments/283/283317-87d679385ba8289ec71a2e688e9c3cb2.jpg?hash=-e2PSo75t3)
