I have a service contract and auto-delivery for oil. Last year I pulled the trigger a little early and locked in while some here called it pretty accurately. So whaddya think, when or at what price would you lock in your HHO?
True, the price per barrel doesn't always mirror the price at the pump. I don't follow or really understand the commodities markets but I'll read those articles and make a decision if I should lock-in. Thanks for the links.Here's a good article on Bloomberg on oil prices.
http://www.bloomberg.com/news/artic...n-low-40s-if-opec-deal-fails-as-odds-diminish
OPEC is having trouble controlling output so prices may slide down to $40.
However, you also have to take into account the weather in the Northeast which uses huge amounts of heating oil. If we get warm months early on, that will drive down demand and prices like last year. I haven't seen long range weather models for this winter, so I don't know, but it is definitely something to consider.
CNBC has a good article on home heating in 2016. The big takeaway is that last year oil prices crashed and we will not be seeing that again. But they are still low.
http://www.cnbc.com/2016/10/13/youll-be-paying-more-to-heat-your-home-this-winter.html
If you don't mind me asking, what prices are they quoting you right now and how many gallons do you use in an average winter?
I am thinking of adding an oil boiler (I have electric baseboards and pellet stove now, no gas line available in my area). Right now the pellet stove works great, but I figure I would like to have a low maintenance heating option too.
I use 700-800g on avg. I have not called around to my oil company yet so not sure. When I first moved in the owner was using at least 1500g and most likely much much more. First thing I changed out were the non-programmable Honeywell yo-yo t-stats. Have done windows etc and added the stove since.
For reference the boiler is original to the house with separate (new-ish) oil fired hot water heater and the house is around 2800 sq/ft w/ two zones built late 60's w/ decent but not great attic insulation.
No gas here either. Hard to know sometimes what to do. Oil is cheap now but wasn't too long ago is was $4. Hard to beat the convenience of a central heating system though especially considering both me and my wife work so it's worth the expense. In my last house I installed a System 2000 which was a cold start boiler w/ water bank. Unlike my current boiler, during summer it was stone cold for the most part and drastically cut our consumption. I don't know about the long term durability though. Both houses had/have baseboard heat which is very comfortable and even when on. Thinking hydronic or forced air?I am thinking of adding an oil boiler
Not a fan (get it?) of forced air.I was thinking of doing hydronic since I keep reading online that forced air is not as comfortable.
I was thinking of doing hydronic since I keep reading online that forced air is not as comfortable. And if I DIY parts of the project, like running the copper pipes and installing the baseboard heaters, and buying the boiler myself for around $2000, I dream of getting everything installed for $4000-$5000. But I am only in the planning stages now. I have to do some demo in the basement first and then figure out the best place for the boiler.
Thanks for the info.
These two interruptions on the Colonial pipeline are gonna have an impact on supply for sure even though early inventory was good. That will be in the process of drawing down right now both because folks need to be filling starting the season and because some will order a load in reaction to the news.
