Hi folks,
First post here.
I have burned for years a Jotul 550 insert.
I just picked up a Jotul 602 C (UL listed) that needs a new back plate. I already took it apart and aside from two snapped bolts, the disassembly was easy.
This 602 will be going out into a workshop.
However, I've never rebuilt a stove before. I've read several posts here that describe the over all process. So long as all the panels and plates fit properly, it doesn't seem bad at all.
My question revolves around the cement used between all the cast iron plates. A lot of posts here mention it generically as stove cement, etc. I could not find recommendations on brands or types.
I know I don't want the stove gasket cement. That is specific to attaching gaskets.
I believe I want "furnace cement" that is labeled appropriate to "seals metal to metal" (ie not gaskets to metal) and can withstand heat up to 2000F.
I can find plenty of brands pre-mixed in caulking tubes. Anyone have preferences on brands (or ones to avoid?)
Does it always come premixed? Or can you get it in powder form and is there any reason NOT to get it in caulking tubes? Pre-mixed in caulking tubes seems like the way to go to me but I wanted to double check.
And.... from everything I read, the whole process is:
1) clean all current seams
2) dry fit everything to make sure it all fits nicely.
3) apply more cement than needed. Assemble and wipe down the bits that ooze out. Let dry.
4) season stove accordingly.
Right?
Thanks
-A
First post here.
Right?
Thanks
-A
