Hello
Wish I knew of this before it broke, but yes we know how delicate that firebrick is and the weak part over the flame cutout!!
Oh Well, At least I can salvage it by using an inexpensive 12"x18" piece of # 22 guage sheet metal from Home Depot for $7.98!!
(broken link removed to http://www.homedepot.com/h_d1/N-5yc1v/R-202183493/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053)
Just put it under the firebrick and trace it oout with a felt tip marker.
then either using metal cutting sheers or a nice jig saw with fine metal cutting blade and cut out the pattern. It is fine if it is a little less than the size of the firebrick and then it will not bee seen.
Then use High Temp RTV on the back of the brick, on the top of the sheet metal and on both sides of any break or tear in the firebrick.
Squeeze everything together and let dry. You can also get some bolts and washers to secure the corners if you want that nice mechanical connection, but note on the Pelpro any corner screws will not hit the back plane of the stove but check on your stove to make sure it does fit correctly. put something heavy on it to dry!
Good luck
See pics below
Click to enlarge
Good luck
See pics below
Click to enlarge
