Not much expertise here locally on running dhw coil from boiler to water heater.
I'm planning on running pex which will be about 100 feet roundtrip from the boiler to the water heater.
Three questions: Should I go with 3/4 pex or 1/2 pex for this run?
What size pump should I use? It will be a pretty much flat run all the way to my 62 gallon water heater.
Ive been told by the boiler manufacture to run the pump 24/7 to reduce wear on the pump and ensure consistent hot water. Any thoughts?
