Can i ask or beg for some Help from you Pro's & Guru's?
I have a new/used Quadra-Fire Castile i got from a home sellout, and i put this in my garage and here in the NE it has been cold, and my garage has been down to 30 degrees when 5 at night, but 40 usually, so not too sure if too cold to ignight??
But i just put in this used pellet stove and did the soot maint cleaned it up in the fire box area & behind plates and exhust blower, then plugged it in, and exhaust blower runs, the igniter gets cherry red, then pellets eventually drop(which seems to be a delay), but then after a while i exhaust blower shuts off, maybe 5 mins, i didn't time it.... so i have some questions?
1. So being a newby to pellet stoves, i am thinking maybe the pot has ash insulating the cherry heat from heating up the pot to ignite the pellets, is that how it works???
2. Then educate me the Noob newby, does the exhaust blower kick off after so many minutes if the fire doesn't tell the thermocouple there is no fire???
3. should there be a delay from plug in until the auger runs??
4. i assume i should manually throw some pellets into the pot beings it takes a few mins for the auger to run, or is the min or so normal to preheat the pot?
5. do the pellets ignite from the heat through the pot wall, or does the heat & the exhaust blower together force more heat onto a pellet to cause it to burn?
6. Now, i noticed some holes in the pot, i guess that is air flow from the exhaust blower to fuel oxygen into the pot, and how do i clean the holes &/or is there anything special with holes?
7. is there any hole or slot in the pot to allow the cherry red igniter to put more heat into the pot?
Thank you in advance for the education and help?
