Quadra Fire AE - Auger in reverse??
rpsingh
3
Central Maine
Keep getting an "Auger Jam" error message. I totaly cleared all pellets from the auger and feed tube - there was no jam. Now the auger is turning but the pellets aren't making their way up to the top of the tube. Is it possible that the auger is turning in the wrong direction, maybe trying to clear the jam (that isn't there)? I've attached a picture of an auger with an arrow indicating which direction mine is turning (it's not a pict. of my auger). Is this the correct direction? If it is, why aren't the pellets making their way up the tube? If this is the wrong direction, how do I get it to in the right direction?
Thanks
(broken image removed)
i slightly remember a fix for this. Sometimes the motor would go in reverse depending on the way the auger motor was connected to the wiring. Hopefully some one will speak up, i believe it was a molex connector that was causing the problem, but i could be wrong. If you un plug it and plug it back in, does it go the correct direction?
I believe most augars are to turn clockwise looking from the motoer end.
Bkins
if the auger is turning backwards pulling the pellets to the back of the auger then the motor is running backwards obviously , a DC motor can be reversed by swapping leads, an AC motor cannot be reversed that way , only way would be to remove the coil (magnet) and flip it over to reverse the field. or get a motor which is designed to run in the direction the auger is suppose to turn in (they can be had in both directions)
The AE has DC motors. It does try to run in reverse to clear a jam. Does it still say auger jam on the screen? There was some problems with false auger jams from a bad wiring harness on the control board end.
thanks bro, didnt know that. nice catch
Yes it keeps coming up "Auger Jam" on the screen. The auger seems to be stuck in reverse. It is going in reverse even during the start-up before the auger jam error message comes up.
Sounds like a bad optical switch to me, unless you really do have an auger jam.
Is there a timer or something that needs to be satisfied before it can turn forward?
Might try removing pellets and letting it run for a bit, maybe then it'll correct itself?
Just a thought...
Is it still under warranty? My first guess would be the 10-pin wire harness, which has the auger sensor on it among other things, needs to be replaced. Other possibility is that the actual sensor has failed which is less likely.
Try unplugging the stove for 10 minutes or so to clear anything out. See what it does when you first plug it in afte that.
