I have an early (2001 or so) Castile that I use to heat my cottage. It has been quite reliable, though I have replaced the control board a number of years ago.
This morning, the fuel pot filled with pellets and then caught fire, creating, for the first time, a very large fire with smoke coming out of the stove and into the room. A couple of times before the fuel pot has filled completely up but never ignited.
I do clean the stove after each cottage visit and make sure that the ash door opens and shuts all the way. Also make sure that the air holes at the bottom are clean. However, I have never replaced the igniter coil though an extra one came with the unit. Nor have I cleaned the thermocouple tube other than to get the dust off of it.
The stove has been running after that okay.
Any ideas?
Any ideas?
Take a look as the stove cycles on and off on very cold days and see if the green light is still on. If so, then you need a wider range of startup and shutdown temps called 'swing'. Some thermostats provide this adjustment and others don't.
