I have a 6 year old Mt. Vernon which is about 6 years old. Reasonably well maintained. In the last week, the stove will go through a burn cycle and then get stuck in a "shutdown" mode (that's what the display says) and not fire up again even if the temp drops well below where it is set. I've had some limited success with unplugging the stove for 15-30 seconds and then getting it to start again. Now, that no longer seems to work. I thoroughly cleaned the stove last night and got it to run properly into the early morning, then it got stuck in shutdown mode again. In shutdown mode it just vents slightly even though the stove is stone cold and hasn't been hot for hours. There are no useful messages on the display reflecting any sort of error. I'm pretty capable of replacing components on the stove (ignitors, vacuums switches, auger motors, etc), as you have to be to keep these beasts running. But I am at a loss with this one, any input would be greatly appreciated...
thanks
thanks
My stove states every 1000 hours; others every ton or two. Guidelines for exhaust cleaning are dependent on stove, exhaust configuration and type/brand of pellets. Different brand of pellets or used the stove more?
