Hi all.
I found the forum via google - trying to find any information on my current problem. I have to say it seems like a great place and has loads of good information. I'm wishing I had found this place before I bought my insert.
I bought my 4100i about two years ago while I was remodeling my family room. Due to doing everything myself (except for the insert install and flue lining) and trying to work for a living, last night was the first night I had the opportunity to use this unit. I'll also preface the remainder of my discuss (I tend to be long winded :red: ) that the previous insert was an old, heavy cast iron beast that basically just sat in the old fireplace firebox and vented into the firebox (no physical connection)... it was basically just like building a fire. Also, as far as background, I really stink at starting fires; it takes forever to get 'em going.
Anyway, after getting the two air intake knobs set per the manual, I lit the fire (just a small fire, some kindling and 2" dia. sticks). It started going pretty well. After about 10 minutes, I closed the "start-up" air control and waited a few more minutes to be sure everything was going fine. Then I closed the door and resumed watching football. At the next commercial break (about 5 minutes), I noticed that the fire was out and smoke filled the fire box. I'll spare the details of airing out the house
I got the fire restarted and could only keep it going by keeping the door fully open. With cats and dogs, I don't see that being my long term solution
After another 40 minutes, I got the itch to see if the original problem could be repeated. I shut the door and watched the fire gradually die down. Interestingly enough, the fire at the logs migrated to a fire just below the baffle. It reminded me of backdraft. I slowly opened the insert door and noticed the rush of air into the firebox and the fire went back to "normal." I repeated this "test" after the fire got going again, only this time kept the start-up air vent open. Same results.
What I'm guessing is that I'm not getting any combustion air into the firebox, causing the dangerous (?) situation.
Any thoughts on how to correct? I'm secure enough to admit it might just be something I'm doing wrong
Don't hesitate to tell me that.
Thanks so much!!
Dewey
Thanks so much!!
Dewey
