Hi all, new to posting on forums.
I have a Quadrafire 800 built in 1994. I bought it used a few years ago and with the replacement of the snapdiscs and the vacuum switch tubing has worked flawlessly.
A few nights ago it started making a loud clicking sound. I checked everything, found that it was coming from the control box. I pulled the control box took the cover off then put it back in. I could see right away that it was one of the relays making all the noise. Assuming that it was the relay, I looked up the part number and was able to order all four, same manufacturer and part number. I was able to get them in and I still have the loud clicking sound. But now I noticed that my feed auger and the igniter are not shutting off. (im not sure if this was the case before I replaced the relays or not) I know they shut off prior to having problems.
This is how it operates. The exhaust fan never shuts off unless it is unplugged. When you turn up the thermostat, Call light comes on, igniter and auger both come on. Some time after the fire starts the green light comes on, shortly after that the red light comes on solid a few minutes later it starts clicking faster and faster until it is almost a buzz. Any thoughts people?
