My Quadrafire Sante Fe Pellet stove has power and the fan comes on but the pellets don't drop in. I pulled it out, cleaned out all the pellets, removed the auger to make sure it wasn't jammed, and then I found a blockage in the chimney so I cleared that out. I've been reading that it is possibly a snap disc that needs to be replaced. Is this something a "mechanically-inclined" woman can do? I'm the one who cleaned everything out, pulled it out, checked the auger, etc, so I'm confident I can do it myself but I didn't want to waste my time if that's not what it is.
and remove the two wires attached to the box and put a piece of wire between them and wrap it with electrical tape so they don't short out. We're talking 120 volts here. While you have it unplugged, feel for the snap disk located on the back of the drop tube. There's a button between the two wires. Push it in. Did it snap in? If it did, it was tripped. If not, then plug the stove back in and see if it works. If it does, the vacuum switch might be bad. Or something else is causing you to lose vacuum such as bad gasketing around the door.![[Hearth.com] Quadrafire Pellet stove insert not feeding pellets [Hearth.com] Quadrafire Pellet stove insert not feeding pellets](https://www.hearth.com/talk/data/attachments/129/129278-868e974a65064c31f37bbc1bc1659206.jpg?hash=HIuF5Y0N4x)
