Hello.
This is my first post
I have a problem with fumes/emissions smell from my pellet stove. I have tried almost all I can do and I hope someone can help me think of something else to check. Here is what I have done so far:
Cleaned the stove; burn pot, chamber, the upper pan, the tubes, the hopper and feed shoot, the fins on the blower fan and cleaned the stove pipe and tee. Still the smell. Then I replaced the door gasket (for lack of a better term) and that did not fix it. Then I called a reputable tech and he found I had a faulty vacuum switch. First thing he saw was that the original vacuum switch was bad and the plastic terminal could slide in and out and wasn't sealed. So he replaced that and on startup he saw the startup smoke coming out of the back of the stove to the tee for the exhaust piping. He said that whoever installed this did not install an appliance adapter which is required. Mind you the stove is nine years old (in great shape..his comments). So I got one, installed it and used high temp silicon sealant and waited 24hrs for it to cure. But still I have this exhaust/fumes smell in the house. It is less than before I replaced the door gasket, vacuum pump and the appliance adapter but still very present.
When it starts up the red demand light is on and in the control box you can see a blue light with a slow blink rate which at some point turns green. That light goes red after a few minutes but before the main blower turns on.
I don't know much about the safety part of the stove and was hoping someone might know what might be a troubleshooting path to take at this point. I just can't figure out why after all these years its happening. I hope it's not a crack in the heat tubes or back plate I can't see or something.
Any help would be greatly appreciated.
