Question about telescoping stove pipe.
Kathy6971
2
Alexandria, Louisiana
I removed a brick hearth and replaced it with a tile hearth which left a 3 inch gap in the stovepipe running to the ceiling. The original stovepipe is a telescoping pipe and I was wondering how to extend it the 3 inches so I can reattach it . Is there a trick to this?
Max W
Burning Hunk
Feb 4, 2021
209
Maine
What I did was attach it to the chimney adapter at the ceiling first so I had something to pull down against.
Eman85
641
E TN
Take the screws out at the middle. What length is it now? Do you know it will go longer?
Eman85
641
E TN
Thank you for the responses. There doesn’t appear to be any screws in the stove pipe I will try your suggestion.
I'd google and read the installation directions. I know on mine they tell you to install screws in the center. If for some reason the top let go the pipe would collapse, that might be exciting with the stove burning.
