So I've decided on an insulated floor for the progress hybrid stove, and I have a question about how to fix one layer to another. I decided on the following pattern and would like some feed back on how to fix the layers one to the other.. (BTW.. if I'm all wrong about the approach, please let me know and suggest alternatives)
1/4" tile
1/2" cement board (durock)
1/2" micron 300
24 gage sheet metal
3/4 " plywood
First some notes on why I choose what. The tile is for show and for an incombustible surface. The cement board is for a hard back for the tile, and a bit of thermal resistance (R~0.2) . The micron 300 is for most of the thermal resistance ( R~1.0) . The 24 gage sheet metal is to avoid hotspots, and the plywood is for support. I'm not sure the durock is needed.. it's there mostly because tile is normally laid on durock , I know you can lay it on the micron 300, but the guy I have to do tile has never done so before.
Tile to cement boad is is done with mortar, and grout between tiles
Cement board to under layment is done with durock screws.. but should some type of matsic be used? Also I think the screws should go all the way down to the plywood
Micron to to sheet metal is durock screws again , and again.. some type of mastic?
Sheet metal to wood should be roofing nails , and again .. some type of mastic
comments appreciated
--G
1/4" tile
1/2" micron 300
24 gage sheet metal
3/4 " plywood
--G
