Just wondering if you run your combustion blower at a higher rpm constantly, will it shorten it's lifespan vs. Running at a lower rpm?
Thanks
Thanks
I know several stoves if not all that are variable speed exh fans. Think about this for a minute if your stove is set on low very little fuel is dumped into the pot so it takes less air to burn the fuel but if you turn the stove on high more fuel is dumped and you need more air to burn the added fuel efficiently. This is done by speeding the exh fan up. Sometimes this is done automatically by the electronic control board and with others there is a knob that can used to adjust the exh fan speed to fine tune the burn in order to burn different fuels.In general, most combustion blowers run at a constant rpm (to satisfy the vacuum switch) and aren't adjustable via a dial or knob on the control panel. Did you mean distribution blower/fan?
I don't believe that is the case with my Harmans. The combustion blower runs at a constant speed at 119V. The only time that would be adjusted is if one was setting the default draft adjustment upon installation of the stove.[/QUO
If you run the stove at a high temp the exh fan will be running as fast as it can to burn the pellets that are dropped into the pot to achieve the high temp. If you set the stove at a low temp it will auger less pellets and the exh fan motor will run at a lower speed to burn less pellets. As proof turn the stove on high and go outside and put your hand in front of the exh pipe and feel the air being pushed out. Now go back inside and turn the stove down to a low temp. Wait about 45 minutes then go back outside and hold your hand in front of the exh pipe. You should just barely feel a slight air movement.
sometime the vibration is only cause by a displacement of the stove, if you lift one end of the stove and let it bang on the floor instead of put it gently down well this will almost automatically end in a vibration and the impellers can also make noise cause there is a fine gap between the impeller and the casting. it will make a very clear bling bling bling noise, some time you just hit the blower when not running and it will stop.Installed my stove Nov 2014 and the combustion motor had to be replaced two months ago. Tech told,me it's a crap shoot and because the motors are magnetic, oil is of marginal if any value and putting a new motor in is the only real solution when motors start vibrating and making noise.
when we talk about Piazzetta the combustion and the convection fan are totally adjustable from 1000 to 3500 rpm if unlocked. and for now I havent found any North American stove that can do this yet. I have a great taught that Hearthstone pellet stove can do the same. But for now I've written to the company tech, two weeks a go, and still havent had a response from them. They seem to have the same combustion fan motor but is it adjustable ??? maybe with in a month or two I'll get an answer never know. hopping to find a similar product of the Piazzetta in North America and no one as ever came with one.In general, most combustion blowers run at a constant rpm (to satisfy the vacuum switch) and aren't adjustable via a dial or knob on the control panel. Did you mean distribution blower/fan?
None that is still in businessI havent found any North American stove that can do this yet
and which one was that ?None that is still in business
But still one of the most efficient stoves made once you understand themBixby. With the computer program and cable nearly thirty things to mess up![]()
The bearing quality will make a huge difference on how long the motor lasts. A motor could use several types of bearings but where it is located will determine the type of bearing used. The lubricant in the bearing will also play a big role.Unless the winding fails, it is the bearing that determines the life of the motor. There are just so many revolutions of life in a bearing. But, it really will make no difference...assume you need X BTUs of heat in each winter. If you run your combustion blower at a lower speed, the stove will have to run a longer amount of time to get the total needed BTUs to keep you warm. If you run the blower at max speed, then the stove outputs more BTU per hour, and you will run the stove for less total time......so the total revolutions that the bearings are subjected to are the same....and the motor life will be the same.
However, running a motor at lower speed might result in a lower motor temperature.....which might extend the life of the winding or bearing.....but I bet this is not a significant factor as to how long the motor will last.
