Builder Bob said:
I have some questions for a new house I was going to build for myself and was looking for some help. These questions are for those who heat 1,800 to 2,100 sq. ft. with your Fireview. This is to help with stove size and heating capacity. FYI the house will be in middle TN. and have spray foam insulation and good windows.
1. What style is your house? Ranch, cape cod, contemporary, cabin etc.
American Mutt
Seriously - front is a split cape (?), then we added another bit on the back that is hard for me to classify. We have an open loft looking over the living room in the front, 2br on the first floor, stairwell leading up (and down 1/2 flight to front door, then basement), also on first floor is the living room (front of house) what used to be a small dining room where the stove is now, then back room is what we call the family room (the addition) that is 450 sq ft back there in one room, these three rooms make a horseshoe arrangement around the kitchen. There is an L shaped wall that breaks up the LR and the 'stove space'. Kitchen has 1/2 wall overlooking into the family room, large open space looking at the stove. Then there is a bathroom on the same floor. Upstairs is the loft room (above the kitchen). Above the stove room is a full bath. Then there is another bathroom and master bedroom in the original part of the 2nd floor. The addition upstairs has three kids rooms. All in all it is somewhere between 2000 and 2300 sq. ft. I would say - have not measured it to be sure.
Builder Bob said:
2. Where is the stove located in the house?
Guess I covered that. Except to say that there is basement below all the above of course.. not part of the space calculations and therefore a no-op for the discussion I presume.
Builder Bob said:
3. How would you rate your insulation/building envelope?
Above average. House was built in 2000, addition completed in 2007. We've also air-sealed and improved the insulation in attic recently. Blower-door test showed that air-infiltration is likely well below the 'normal averages' for house of our size and we improved it after that
Builder Bob said:
4. Do you heat your whole house with this stove or do you run central heat or other also?
Aiming to do whole house except for basement. The two bedrooms at far end of the first floor are questionable for effectiveness...
Builder Bob said:
5. What is the average indoor temp you keep the house during winter?
Our target temp is 65 for living areas, cooler for sleeping quarters. Obviously we'll be warmer around the stove.
Last year we were using the VC Encore. It is rated below the FV in all BTU numbers - peak, EPA tests etc. I only expect to have better results this year with the FV (especially given that it generally operates better!). So my working assumption is that my results from last year are reasonably applicable to the future. What I found was that we were able to heat the house to 70 in the kitchen and family room area - far end of family room would be cooler of course. Upstairs would be 68ish in the loft. Our Master BR would be 64 or perhaps cooler - especially if the door was closed for any lenght of time. Kids rooms upstairs lost a lot of heat through windows (no curtains) so if doors were closed then look out there, but once opened we could feel the cold air flow out and warm air go in. The bedrooms at the far end of the first floor were the hardest to heat as basically the heat wanted to flow upstairs and heat all that space first before heading down the hall - not too surprising. There is no line of sight path from stove to that hall or those rooms so it has to be convection/warm air heating to reach those rooms and they are on top of the garage to boot.
I don't know the timeframe for your decision, but I'll be posting my results as time goes one. I tend to be a data junkie so I do track temperatures in different parts of the house so I may be able to give you some objective findings if you would like. I need to build up a data set before I'd consider them to be overly useful. For example, preliminary analysis of today's data suggests that the stove may have reversed an approx .3*/hr heat loss at the center of the house into a .5*/hr or greater gain @20 degree indoor/outdoor delta and stove running at a low temp (approx 400f surface) including the startup time/temps. Not a great stress test - neither a huge inside/outside temp delta nor was the stove running very hot when you consider it can run up to 650f surface temp safely.
